Waterjet Machine with Advanced Taper Compensation
February 26, 2020Comments
At FABTECH 2019, Omax demonstrated its 80X-series JetMachining Center, a waterjet cutting machine featuring the company’s Tilt-A-Jet taper-compensation technology. The 80X series incorporates multiple table sizes and customizable work envelopes for precise abrasive waterjet cutting of large-scale components and multipart projects, with the Tilt-A-Jet technology reportedly attaining virtually zero taper for precision, high-rate cutting of parts with square, taper-free edges, including interlocking pieces and dovetail fittings. Using the water-resistant Rotary Axis head for production of complex 3D parts, the 80X’ capabilities expand to cut in as many as six axes.
See also: Omax Corporation
Technologies: Cutting
There are no comments posted.New Line of Wear-Resistant Waterjet Nozzles
Friday, February 24, 2023
