Spotlight on Troubleshooting
October 1, 2017Comments
HTM Sensors will show its Spotlight technology for identifying the inputs within a plant causing downtime. The technology shows on the HMI screen exactly where the input is found so that a solution can be deployed to replace the product, change the location, or increase protection of the input.
Spotlight is designed for use with robotic weld cells. The analytic software knows the cycle time of a good part, and if there is downtime because of a particular input. The amount of time and events count are traced to the input level for analysis and investigation.
www.htmsensors.com
See also: HTM Sensors
There are no comments posted. Sensing/Electronics/IOT
May 28, 2024
Intelligent Sensors Aim to Enhance Management of Compressed-...
May 28, 2024
