Heavy-Duty Pneumatic Die Lifters
October 1, 2014Comments
Pacesetter Systems, Inc.
Booth B1661
Stop by the Pacesetter booth for a look at its line of Air Glide heavy-duty pneumatic die lifters, available with ball bearings for multidirectional movement or with cylindrical bearings for inline movement. Each features extra-large precision-ground bearings and high-quality o-ring seals. Using the die lifters, it takes only 40 lb. of force to move a 2000-lb. die.
Air Glide lifters use standard shop air pressure and install easily in standard ANSI T-slots. Because they have no internal air bags or bladders to corrode and crack, Air Glide rollers resist the harsh chemicals and lubricants used in metal stamping. The lifters are available from stock in 5⁄8-, 3⁄4- and 1-in. sizes in lengths to 72 in.www.pacesettersystems.com
See also: Pacesetter Systems
Technologies: Tooling
There are no comments posted. Tooling
Peter Ulintz Monday, May 13, 2024
Managing Off-Center Press Loads—What Every Press Technician ...
