Tooling by Design
Forming Speeds: Why Ask Why?
By: Peter Ulintz
Tuesday, May 1, 2018
Historically, experienced tool-and-die makers spent 4 yr. or more training apprentices on the hows of their craft without exploring the whys, relying, instead, on accepted practices and handbook references. While handbooks are great, sometimes rules must be questioned.
Take forming speeds for example. Several handbooks list the recommended forming speed for low-carbon steel at 55 to 80 ft./min. Many stamping companies use this information to establish the number of parts produced per min., a potentially big mistake.
From a metal-stamping business viewpoint, deforming sheetmetal produces revenue. Deforming more quickly generates profit. From a tooling viewpoint, deforming sheetmetal produces heat. Deforming more quickly generates numerous problems, all of which contribute to the maximum speed at which a particular part can be formed.
Factors to Consider
Let’s first consider the single-action mechanical press found in most press shops. All presses have a maximum working capacity, usually specified in terms of tonnage ratings. When a mechanical press is rated with a maximum working capacity of 600 tons, this means the machine carries out 600 tons of work with the slide approximately 0.25 in. above bottom dead center (BDC). From high-school physics, we recall work defined as a force working through a distance, expressed as:
W = (f)x(d)
The working capacity (W) of a press—a function of the machine’s structural design, gearing, motor size, flywheel energy and other variables—is fixed by nature of the manufacturer’s design. If the working distance (d) increases, when deep drawing a cylindrical shell 2 in. above BDC, the force (f) available to carry out the work decreases.
Increased forming speed further complicates the situation because forming steel more quickly requires greater stresses. If the selected press does not have a reserve work capacity to accommodate the increased force requirements, the motor may overheat as it tries to maintain flywheel speed or, in extreme cases, the press may stall. Factor in the increased forces needed to pierce and trim at higher speeds and many problems can arise in progressive and transfer tooling, including excessive tool defections, damaging tipping moments, and increased snapthrough or negative tonnage forces that can shock and break tools—and sometimes presses.
Tooling temperature, one of the most important factors, may limit deep-drawing and forming speeds. A high temperature at the tool-to-sheet interface can cause lubricants to break down. This leads to microscopic welding of the sheetmetal to the tools, called galling. Historically, galling had been a criterion for establishing some of the forming-speed limits still found in handbooks.
In addition, tool steels expand when their temperature rises. This expansion decreases punch-to-die clearances and can result in excessive stretching, leading to tears or breaks in the stampings.
Addressing Tears or Breaks
If tearing (or necks) occur in production, slowing the press is a common practice, and with good reason. The slower stamping process produces less heat, whereby the tooling temperature may drop considerably and, as a result, the stamping no longer tears. Initially, it might appear that reducing the press speed allows the material more time to flow. However, the improved forming likely results from the die cooling enough to provide adequate clearance for the sheetmetal to flow.
Sometimes, a small increase in tool temperature can cause stampings to tear or break, a common problem in dies that have been cut to nominal material thickness with no allowance for material thickening in drawn corners. The machined punch-to-die clearance, based on initial material thickness, may be insufficient in these areas because the material thickens when drawn into the corners.
It is not unusual to experience galling in areas of insufficient clearance after just a few hits during die tryout. Applying more lubricant, or coating the die steels with a high-tech surface treatment, is a common, though not proper, solution during die tryout. Unfortunately, when the die temperature rises during production, the problem often returns as thermal expansion reduces die clearances.
The cheaper and more reliable solution for addressing galling—programming and machining the proper offset clearances in draw corners—also happens to be the proper die-engineering practice. MF
YOUR NAME *
EMAIL *
WEBSITE
