Battery-Powered Die Changer
July 1, 2008
A single-station die changer from Aura Systems Inc., Decatur, IL, offers
Battery-powered die changer
12,000-lb. capacity and a roller deck that ranges from 11 in. lowered to 54 in. raised. It boasts an integral hydraulic wheel motor with 180-deg. steering and a tight turning radius. Integral docking hooks make for quick and safe press-to-storage rack tool exchange. Speed control is variable to 150 ft./min., and the unit emits visual and audible motion alarms. Other features: on-board automatic battery charger and battery-charge level gauge, over-travel limit switches for lift and push-pull, and a main-power disconnect E-stop switch.
Aura Systems Inc.: 217/423-4100; www.aura-systems.com
Industry-Related Terms: Die, Gauge
See also: EMH Systems
Technologies: Tooling
