Draw-Bar Cover Protects Milling-Machine Operators
May 1, 2017Comments
Milling machines can endanger operators should they come into contact with the machines’ high-speed rotating draw bars. Protect operators from this inherent danger by implementing this new draw-bar cover from Rockford Systems, designed to protect workers from rotating shafts 7 ft. or less from the floor or working platform.
The cover guards the turning draw bar with a non-rotating, smooth, welded-steel enclosure, firmly secured to the mill with a ring magnet and a 24-in. zinc-plated steel anchor chain. Simple to install, the draw-bar cover prevents clothing, hair or hands from being grabbed by the moving shaft. The welded-steel enclosure has a 4.95-in.-dia. base and 7.125-in. extrusion, and weighs 4 lb.
Rockford Systems LLC: www.rockfordsystems.com
See also: Rockford Systems, LLC
There are no comments posted.Avoiding the 7 Deadly Sins of Stamping: Part 2—Out-of-Sequen...
Art Hedrick Friday, March 29, 2024
Q: Many Years Back You Published the "Ten Tooling Laws," Can...
Thomas Vacca Monday, February 26, 2024
The History of 3D Milling in the Die Shop
Peter Ulintz Monday, February 26, 2024
