Brad Kuvin Brad Kuvin
Editorial Director
6-kW Fiber Laser Moves the Tipping Point
August 1, 2017
Metal-fabrication job shop BMG of Kansas, Inc., from its 50,000-sq.-ft. location in Hesston, KS, churns out cut and formed mild-steel parts by the tens of thousands, with a focus on mild steel from 22 gauge to 1 in. thick. With the sweet spot being 14-gauge sheetmetal to 1⁄2 in. plate, high-power laser cutting has been the company’s go-to fabrication process, supplemented by state-of-the-art press brakes (some with automatic tool-change capabilities) to help keep up with the escalating part volumes flying off of its lasers.
Early in 2017, fabricator BMG of Kansas brought in its second 6-kW fiber-laser cutting machine to round out its stable, for work thicker than 1⁄4 in.
BMG originated as an OEM manufacturer of hay-processing and related farm equipment in 1985; it evolved fully into a job-shop fabricator in 2000, under the ownership of the Brenneman family. Today, according to COO Doug Brenneman, the company operates four laser-cutting machines (all Amada units)—a 6-kW CO2 machine and three fiber-laser machines (one 4-kW and two 6-kW units).
“Since 2003, when we brought in our first laser-cutting machine (a 2-kW Amada Pulsar CO2 model),” says Brenneman, “we’ve owned and operated a total of 10 Amada laser-cutting machines and logged more than 250,000 hr. of cutting time. We went from 2-kW machines to 4-kW, and then to 6-kW over the years, and even added rotary indexing at one time to laser-cut tube, pipe and structural parts. Along the way, we often doubled cutting speed with each upgrade, including in 2013 when we installed our first fiber machine—a 4-kW Amada FOL-AJ equipped with an ASLUL material-storage tower.”
A Fiber-Laser’s Work is Never Done
BMG’s initial fiber-laser cutting machine, when cutting with nitrogen, doubled the cutting speed on material to 1⁄8 in. thick compared to using CO2 machines. Cutting speed for the company doubled again when it upgraded to a 6-kW LCG-AJ machine (above). As an example, when processing 11-gauge mild steel (the nest on the right), cutting speed went from 300 in./min. with the 4-kW fiber laser to 630 in./min. with the 6-kW machine. On the left: 7-gauge steel cut at 310 in./min.
That initial fiber-laser cutting machine, says Brenneman, when cutting with nitrogen, doubled the cutting speed on material to 1⁄8 in. thick compared to using CO2 machines. Cutting speed for the company doubled again, when it upgraded to a 6-kW LCG-AJ machine (see the accompanying graph).
As an example, Brenneman says that when processing 11-gauge mild steel, cutting speed rose from 300 in./min. with the 4-kW fiber laser to 600 in./min. with the 6-kW machine.
“And, with that 6-kW upgrade we were able to move all of our 1⁄4 in. and thinner work to the fiber-laser machine,” he says. “That new machine, added in 2015, really covered a majority of our product range.”
Early in 2017 BMG brought in its second 6-kW fiber-laser cutting machine to round out its stable, “for work as thick as 1⁄4 in. with the high-speed nitrogen cut,” Brenneman explains. “And, as a backup plan to cut 3⁄8-in. plate should our CO2 machine be running at capacity or go down for maintenance, we’ve developed a specialized oxygen-cutting process. We can use that process to cut the plate using the 6-kW fiber machines.”
Shown is how cutting speed and, ultimately, the processing time required to cut specific parts at BMG, varies based on material thickness and the type of laser-cutting machine.
Brenneman again offers an example, citing a cutting speed of 70 in./min. on 3⁄8-in. plate with the 6-kW CO2 machine, and 95 in./min. on the 6-kW fiber machine cutting with oxygen.
That oxygen process, Brenneman explains, revolves around tweaking the cut conditions provided by Amada. Technicians adjust laser-pulse frequency as well as the ratio of beam power to cutting speed, to obtain the desired edge quality.
“Now that we have refined the oxygen-cutting process for cutting 3⁄8-in. plate on the fiber machines,” says Brenneman, “we’re turning our attention to cutting 1⁄2 in. plate on the fiber machines.”
BMG’s laser-cutting machines run 24 hours/day, five days/week. However, the company does not run lights-out or unmanned. Instead, explains Brenneman, it prefers to staff the shop while the machines run, so that operators can pull parts from the nests and stack them immediately, rather than coming into work in the morning facing stacks of nested parts waiting to be separated and sorted.
“We have found that the labor savings gained by sorting each nest as they are completed provide a better return than does running lights-out,” Brenneman says.
Making Nitrogen
Another cost-saver for the company: use of a pressure-swing adsorption (PSA) system to generate the nitrogen it needs to feed its four laser-cutting machines. Compared to the costs of having nitrogen cylinders delivered to the shop by a local gas distributor, or having said distributor regularly fill an onsite bulk tank, generating nitrogen onsite from dry, compressed shop air with its PSA system saves BMG thousands upon thousands of dollars/yr.
Analysis conducted by Brenneman shows that on an annual basis, the shop would have to spend $186,000 on liquid nitrogen. Generating its own nitrogen costs the company $56,000/yr. to feed its four machines, for an annual savings of $130,000.
“In order for us to grow and remain competitive,” Brenneman says, “we have to reinvest in the technology and equipment to meet our production goals, without increasing our floor space. A big part of that achievement is upgrading the laser-cutting machines as the technology allows so that we can increase efficiency and productivity, and expand our capabilities.”  MF
Industry-Related Terms: Edge, Gauge, LASER, Plate, Run, Thickness
Technologies: Cutting, Fabrication
