New Product Article
Strong Flap Discs for Quicker Material Removal
Tuesday, May 15, 2018
The patented Polifan-Strong flap discs from Pferd remove more material in less time than most other consumable abrasives for angle grinders, according to company officials. Featuring a unique extended flap design for consistent and aggressive grinding to the last grain, this disc reportedly delivers optimal performance for high-powered angle grinders. Combining maximum metal removal and long tool life cuts downtime by reducing tool changes and lessens labor costs by reducing grinding time.
Watch the video
The flap discs find use in steel construction, foundries, ship building, automotive, tank construction, fabrication and pipeline work. The coated flaps are produced with a high-performance zirconia alumina abrasive, available in 36-grit for coarse grinding of steel and weld seams, or 50-grit for edge work such as chamfering, and deburring. The discs are available in 4.5-, 5- and 7-in. dia. with either plain 7/8-in. bore or 5/8–11 threads.
Pferd Inc.: www.pferdusa.com
See also: Pferd Inc.
YOUR NAME *
EMAIL *
WEBSITE
