Corrosion Protection
June 1, 2018Comments
Cortec Corp.’s FlashCorr VpCI, a blend of surfactants, chelating agents and corrosion inhibitors, protects metal surfaces from corrosion. It can be applied to sand-blasted, water-blasted and wire-brushed surfaces to stabilize and protect against flash corrosion before application of primers, paints and protective coatings. The product reduces application costs and improves adhesion, thus allowing effective and long-term performance of protective-coatings systems. Applications include salt spreaders, snow plows, blowers, boats, commercial vehicles, etc. It also is highly recommended for protection of machinery and engine blocks as well as marine equipment.
Cortec Corp.: www.cortecvci.com
See also: Cortec Corporation
Technologies: Materials
There are no comments posted.Chemcoaters Launches InterCoat ChemGuard for Body-in-White S...
Tuesday, April 6, 2021
Heating Helps Forming, Part 1: Hot Stamping of High-Strength...
Eren Billur Wednesday, July 29, 2020
Stamping High-Strength Stainless? Coating is a Tool Lifesave...
Lou Kren Wednesday, July 29, 2020
