Achieving Premium Results with Plasma Cutting
By: Al Hoist and Rachel Scheck
Al Holst is product manager and Rachel Scheck is a communications specialist at Park Industries, St. Cloud, MN; www.parkindustries.com
Sunday, July 1, 2018
Fig. 1—Basic plasma-torch design.
Automated plasma-cutting systems can produce accurately cut parts with a variety of gas combinations, but what’s under the surface will affect your final product quality. Different gas combinations will react with the cut metal edge and affect weldability, making the selection of the appropriate gas combination a key component in ensuring good quality.
The gases selected for automated plasma cutting depend on the type of torch used by the plasma system. Some torches offer only a few choices and others a multitude of possibilities. This article takes the mystery out of deciding the best choice for your cutting needs.
Basic Torch Design 101
Plasma torches are either a single-gas-input or dual-gas-input design. Typically, single-gas torches operate at currents to 125 A. The single-gas input splits inside of the torch into plasma and shield flows. When the operation exceeds 125 A, the increased heat of the arc requires that the torch be liquid-cooled. Virtually all liquid-cooled torches feature dual gas-input designs. Dual-gas torches have separate pathways for the plasma and shield gases, allowing the torch leads to deliver the gases to the torch head through two separate hoses. The plasma and shield gases can, therefore, be different, as can delivery pressures and flows.
Systems with Single-Gas Torches
Fig. 2—Steel cut with O2 plasma/air shield with iron-oxide film.
Fig. 3—Steel cut using O2 plasma/air shield with iron-oxide film removed from right side.
Fig. 4-7—Images show representative results of cutting stainless steel from the gas combinations listed.
Fig. 8-11—Images show representative results of cutting aluminum from the gas combinations listed.
Low-cost automated plasma-cutting systems, configured with single-gas torches designed to cut all sheetmetal types using compressed shop air, may not deliver the quality required by many customers. The reason why: The cut face of steel plate, cut with air, includes large amounts of dissolved nitrides, with the air being roughly 78 percent nitrogen and 21 percent oxygen. When a gas-metal-arc weld (GMAW) is applied directly to the cut surface, nitrides often are trapped inside of the weld as it solidifies. Grinding the cut edge surface before welding will eliminate the nitriding issue. When cutting aluminum with air plasma, the cut face becomes heavily oxidized and grainy in appearance, and will require grinding before welding on the cut face. The cut surface of stainless steel also will be heavily oxidized. The surface, dark gray and crusty from the formation of nickel oxides, requires grinding before welding.
Fabricators can use cylinder gases such as nitrogen or nitrogen-hydrogen (95 N2 – 5 H2) with some single-gas torch systems in an effort to improve the cut-surface quality of nonferrous metals. However, the required total flow rate for a 125-A single-gas plasma torch, as much as 550 ft.3/hr., increases gas costs because a cylinder with a 330-ft.3 capacity empties in 36 min.
Plasma systems configured with single-gas torches offer significantly shorter consumable life and much higher operating cost than plasma systems configured with liquid-cooled, dual-gas torches. Air-plasma systems do not include long-life technology, which ramps amperage and gas flow up and down at the start and stop of every cut, ensuring consistent cutting performance over the life of the consumables. Without such technology, cut quality changes dramatically over the life of a consumable set.
Dual-Gas Systems
Today’s automated precision plasma cutting systems are configured with liquid-cooled, dual-gas torches; computer-controlled, switch-mode power supplies; and sophisticated automatic gas-delivery systems. Cut charts embedded into CNC controls automatically adjust cutting parameters and select the required gases based on the material type and thickness selected. Also, most systems include technology that adjusts amperage and gas flow at the start and stop of every cut. This technology significantly extends consumable life and ensures consistent cutting performance over the life of consumable.
The type of workpiece material and its thickness, and the cut-face weldability required determine recommended gas combinations. To deliver premium cutting performance, manufacturers of automated plasma systems make large investments in developing consumable sets designed to operate at exact amperages using specific gas combinations.
Businesses seeking contract plate-cutting opportunities will find that the vast majority of competing contract shops operate plasma-cutting machines configured with precision high-definition plasma systems. Shops pursuing contract plasma cutting also will be competing with the laser- and waterjet-cutting processes. Today’s contract cutting firms offering plasma cutting must consistently deliver accurately cut parts on time, at competitive prices, with minimal bevel, little or no dross, and weldable cut edges.
Gas Combinations for Mild Steel
All manufacturers design their automated precision plasma-cutting systems to use oxygen as the plasma gas for cutting steel. Oxygen plasma produces the best cut quality, least amount of dross, fastest cutting speed, most weldable edge and most forgiving parameter settings. At 30 and 50 A, most precision automated plasma-cutting systems use oxygen plasma and oxygen shield. Shop compressed air is used as the shield gas above 50 A.
Plasma, laser and oxyfuel cutting processes use oxygen when cutting steel, and they leave a thin film of iron oxide on the cut surface. This thin film can be removed easily with an abrasive treatment. However, if not removed, paint applied to the cut surface may flake off (Fig. 2-3).
Gas Combinations for Stainless Steel
For general-purpose cutting, most manufacturers of automated precision plasma systems suggest cutting stainless from thin-gauge to 1.5-in. thick, using either shop compressed air or nitrogen plasma, with either nitrogen or shop compressed air as the shield gas. The cut should be free of top and bottom dross, have a relatively smooth cut surface and minimal bevel. Weld metal applied directly to the cut face requires surface grinding.
If weld metal will be applied directly to the cut surfaces from thin gauge to 0.5-in. thick, consider gases such as F5 (95 N2 – 5 H2) plasma and N2 shield to produce weldable cuts. Some plasma systems include a gas-delivery system with the ability to blend argon, hydrogen and nitrogen for customized plasma-gas mixtures based on thickness and cutting amperage. For plates from 0.5 to 1.5 in., Ar-H2-N2 blended plasma-gas mixtures with N2 shield produce premium results—smooth, squared edges, often with a golden color. A few manufacturers offer the ability to use nitrogen plasma and tap water as the shield. The N2/water process produces a very square and weldable edge at a low cost for thin-gauge to 1.5-in.-thick plate.
Note that gas combinations such as F5 plasma/N2 shield and Ar-H2-N2 plasma/N2 shield require a narrow window of parameters (speed and voltage) to produce premium results. Some adjustment to cutting speed and voltage may be required to optimize cuts (Fig. 4-7).
Gas Combinations for Aluminum
For general-purpose cutting, most manufacturers of automated precision-plasma-cutting systems suggest cutting aluminum from thin-gauge to 1.5-in. thick, using either shop compressed air or nitrogen plasma, with nitrogen or shop compressed air as the shield gas. The cut should be free of top and bottom dross, and have a relatively smooth cut surface with minimal bevel. However, the cut face will be heavily oxidized, rough and grainy. Grinding will be required if weld metal is applied directly to the cut face surface.
Blends of argon, hydrogen, and nitrogen plasma and nitrogen shield that deliver premium results should be considered if weld metal will be applied directly to the cut surfaces of aluminum from 0.25- to 1.5-in. thick. Edges cut with these combinations are quite smooth, very square and weldable. A few manufacturers also offer the ability to use nitrogen plasma and tap water as the shield. The N2/water process produces a very square and weldable edge at a low cost, from thin-gauge to 1.0-in.-thick plate (Fig. 8-11). MF
See also: Park Industries, Inc.
YOUR NAME *
EMAIL *
WEBSITE
