18-V Large-Sized Grinder
August 1, 2018
Milwaukee Tool has introduced the M18 Fuel, featuring a 9-in. grinding capacity and billed as the world’s first 18-V large-sized angle grinder. The 7-in./9-in. model generates the power of a 15-A corded angle grinder, and reportedly is as much as 2 lb. lighter than the leading corded unit.
The new grinder combines three Milwaukee innovations: the PowerState brushless motor, which delivers speed and capacity to grind and cut through difficult applications without slowing down; the RedLithium high-output HD12.0 battery that provides 50 percent more power, runs 50 percent cooler and delivers 33 percent more run time than the M18 RedLihtium HD9.0 battery; and RedLink Plus intelligence to ensure maximum performance of the tool under load and prevent against overload and overheat.
This grinder is compatible with Milwaukee Tool’s entire M18 line of more than 150 power-tool products.
Milwaukee Tool: www.milwaukeetool.com
Industry-Related Terms: Grinding, Model, Run
See also: Milwaukee Tool
Technologies: Finishing
