Power Supply Now Equipped for CMT Welding
March 14, 2017Comments
Fronius has increased the functionality of its intelligent TPS/i Robotics power source, designed for robotic arc welding, to handle the cold-metal-transfer (CMT) welding process. Users benefit from the combination of high and reproducible weld-seam quality and optimum welding speed. The intelligent, modular setup comprises interconnected and synchronized components, and a high-performance processor and high-speed bus that enable quick data exchange. Two synchronized wire feeders ensure dynamic and precise wire feeding, and the compact push-pull welding torch provides easy access to weldments.
Compared to other gas-metal-arc-welding processes, CMT welding reduces heat input and enables continuous regulation from cold to hot. This results in a stable arc and minimal spatter, even at high welding speeds. The process finds use in a variety of applications, including welding light- and medium-gauge sheet from 0.5 to 4 mm thick, thick root passes and galvanized steel.
www.fronius.com
See also: Fronius Usa LLC
Technologies: Bending
There are no comments posted.Custom Robotic Sheet Metal Folder
Monday, November 17, 2025
New Ironworker and Belt Grinder, Plus Demos
Friday, July 25, 2025
Sheet Metal Folding and Forming
Monday, July 7, 2025
