Engine Manifold With Two-Blade Cutting
October 1, 2019Comments
Transfluid
Booth D46577
Transfluid shows its T bend system, which enables the processing of tubes to 60 mm with a bending radius of 1 x D. Most of the tubes produced in this case have two or three bends, with the cut made straight after the last bend or between two bends with no additional follow-up cuts required. The bending machine for this solution features a centerline booster and three bending planes, plus the plane where the cutting tool is used.
See also: Transfluid Maschinenbau GmbH
Technologies: Bending
There are no comments posted. Bending
Lou Kren Tuesday, November 1, 2022
New Sheet and Tube Fabricator Has Lofty Goals
Thursday, September 29, 2022
Flat-Sheet Laser System with Automated Material Handling
