Laser Cutting, Automation and More
August 28, 2025Comments
Prima Power
Booth A1338
Prima Power will exhibit an
impressive lineup of machines: Platino Linear with compact server, eP Genius
1030, Shear Genius with loading device, picking and stacking robot, and the new
BCe Smart+ 2720.
The Platino Linear 2D laser offers a 22% smaller footprint for efficient space use and features a maintenance-free linear drive, company officials say, to minimize downtime and costs. Its open, cantilever design provides full work-area access, while a synthetic granite frame ensures vibration absorption and thermal stability, and an aluminum carriage delivers an optimal weight-to-rigidity ratio. With Smart Cut, Gas Mixer Cut, and Eco-Touch Cut technologies, it can cut cycle times by as much as 30% and reduce gas use by as much as 40%. The Adaptive Cut system auto-adjusts focus and beam diameter, and the Safe Impact Protection System prevents collision damage.
Prima Power will also showcase the eP Genius 1030, an electric press brake that utilizes a servo-electric drive system that delivers high accuracy and repeatability, along with a user-friendly interface. Its energy-efficient design minimizes power consumption, while the compact footprint optimizes floor-space utilization.
