Press-Feed Catalog Showcases Built-in Diagnostics, Touchscreen Programming, More
April 1, 2010Comments
True Feed press feeds from Waddington Electronics, Cranston, RI, get top billing in a new catalog that delves into product design, performance and construction features. The direct-drive feeds include high-speed air pilot release or super-speed servo pilot release, gearing between top and bottom rolls, touchscreen programming and built-in diagnostics. Speed peaks at 1500 strokes/min., accuracy to 0.0005 in. Integral sine-encoder feedback provides resolution in excess of 2 million counts/ revolution. A direct load connection eliminates costly maintenance of gearboxes, pulleys or belts. Maximum stock width, 25 in.; max. stock thickness, 1⁄8 in.
Waddington Electronics: 401/781-3904, www.waddingtonelectronics.com
See also: Waddington Electronics Inc.
