Servo Feed Line Featured, with Automated Straightener Setup
July 16, 2021Comments
Coe Press Equipment
Booth D46924
Coe Press Equipment will display a 24-in.-wide servo roll feed with its patent-pending Series 406 4- by 24-in. straightener with 4-in. pinch rolls. Booth visitors will see the enhanced designs and robust components that enable the equipment to process everything from aluminum to advanced high-strength steels. Additionally, Coe’s advanced PLC controls will be demonstrated, with a focus on its Work Roll Advisor feature that automates straightener setup.
Coe equipment is based on modular designs with rugged and precise component construction to handle coil materials to 78 in. wide, 0.010 to 0.725 in. thick, and coil weight to 60,000 lb.
