Integrated Plate Processing Combined With Automated Material Handling
June 20, 2025Comments
Tecoi USA
Booth A5478
Tecoi USA showcases its total system solution, featuring large-format plate-processing machines that integrate machining combined with StockTec automated material handling. The large-format Thor (Tecoi Hyper Operative Range) plate-processing machine integrates plasma cutting and a beveling system with oxyfuel cutting. It also integrates mechanical cutting, including milling, drilling, tapping, countersinking, marking, etc.
Tecoi’s LS-series laser and drilling machine incorporates the choice of either one or two drilling heads, maximizing its large-dimension laser-processing and cutting-station capabilities. Each drill head includes as many as six tools, with 22-hp 4000-rpm machining power per head, drilling to 22 mm and tapping to M16, and tool change that can be accomplished in seconds.
