Compact, 3-Ton-Capacity AGV
May 26, 2023Comments
The new Stäubli PF3 automated guided vehicle (AGV) features a compact design that enables the lifting and carrying of payloads to 3 tons with high positioning precision (±5 mm).
The PF3 base measures 1750 by 970 mm with a 350-mm height without lift unit and 400-mm height with the unit. For simplified integration, it offers standard software interfaces, and electrical and mechanical interfaces allow for third-party add-ons. PF3 charging reportedly is quick—to 80 A—and the unit can last to 7000 charging cycles. Side access to components, and quick-change capability of critical parts eases maintenance. Safety-wise, the PF3 features a human safety scanner, five emergency-stop buttons, status communication via an LED strip and collision-avoidance technology.
The high capacity of the PF3 and even larger-capacity Stäubli AGVs frequently find use in automated die and material movement at OEMs and Tier-One suppliers, company officials told us at Automate 2023.
See also: Staubli Corporation
There are no comments posted.Automation, Industry 4.0 Driving Advanced Material Handling ...
Lou Kren April 26, 2023
Autonomous Mobile Robots Increase Efficiency, Improve Morale...
December 2, 2022
Customized AMRs
Friday, March 8, 2024
