Finishing Well
July 25, 2025Comments
Finish line. Fast finish. Finish first. Finish well. A lasting finish.
Metal finishing has advanced in myriad ways that abbreviate the time to completion, and improve coverage, adhesion and final quality. Whether a component has been powder- or liquid-coated to imbibe a color and protect, anodized to a certain shade of sheen, deburred to enable safe handling, sanded to a specified smoothness, or doused in a rust preventive, the final stage of a part puts the lid on the box.
Finishing a fabricated component or assembly inscribes a signature. It speaks, “All done here.”
Finishing Marvel
Chicago, host of FABTECH 2025, which includes the Finishing pavilion, also hosts one of the world’s most extraordinary finishing-technique marvels: Millennium Park’s Cloud Gate, or “The Bean” as it’s affectionately referred to. Cloud Gate, designed by artist Anish Kapoor, assumes the shape of an omphalus, which in and of itself is a design and metal-fabrication marvel. However, it is the seamless mirror finish, intended to resemble liquid mercury, that epitomizes the apex of excellence in metal finishing.
Two decades ago, I interviewed the company tasked with fabricating the 110-ton, 66-ft.-long by 33-ft.-high stainless-steel sculpture: Performance Structures Inc. (PSI), Oakland, CA. I also talked with MTH, Villa Park, IL, the contractor tasked with reassembling, welding, grinding and finishing the landmark piece to that seamless, mirror finish to reflect the city around it—and the people under it.
Achieving that seamlessness was a labor of love and a finishing feat.
Finishing a Labor of Love
One could hardly guess by looking at the placid surface of the monumental stainless-steel sculpture how much metal and mettle lie below its surface. Sealed within Cloud Gate are the stories—5-plus yr. in the making—of more than 100 metal fabricators, cutters, welders, finishers, engineers, technicians, ironworkers, erectors and managers.
Many worked overtime, performed shop work in the middle of the night, camped out onsite and toiled in 110-deg. temperatures in full Tyvek suits and half-mask respirators. Some worked in gravity-defying positions, suspended from harnesses while holding tools, changing belts and working on slippery slopes. All went above and beyond so that the impossible could be made possible.
Finishing and polishing Cloud Gate’s welds to achieve a seamless appearance was one of the toughest aspects of the onsite erecting and assembly.
White-paper
