Refining its design approach, the Hammond Roto-Finish team determined the number and type of robots required to achieve proper finishing with the knowledge that the end user had no prior experience with robot-led automation. The solution: Three robots polishing and three robots buffing, which would meet the customer’s tight timeframes not only for system installation but also for production throughput.
The completed automated-finishing system features an indexing table that allows a formed or fabricated workpiece to be rotated to a specific position. Surrounding the table: seven flexible, heavy-duty Kawasaki Robotics BX200L industrial robots —featuring payload capacities of 200 kg and horizontal reach of 8.5 ft.—and a high-speed Kawasaki RS020N industrial robot.
Rapid, Staged Throughput
The BX200Ls feature hollow wrists for housing cables and hoses, and lightweight arms to provide functionality, flexibility and efficiency to perform two stages of polishing, two stages of buffing, two stages of color buffing and a clean wipe. The RS020N features dual-ended end-of-arm tooling that removes each finished part from the index table and places an unfinished part on the station for simultaneous processing. The finished parts then transfer to a conveyor for further handling and packaging.
“By using robots instead of instead of dedicated heads on rails, if we had an issue with the automation path, we could just touch up the program without having to make mechanical changes to the system,” Hammond says.
Per the customer, automating the process resulted in reduced cycle times and improved quality control via consistent and repeatable finishing. It had required a production KPI of less than 15 sec./part in each finishing step, and each step met this target, with the indexing table served by multiple robots ensuring that a part could be unloaded every 12 sec., thus maintaining throughput. And, the indexing table allows parts to move efficiently through multiple finishing stages—outer wall, face and radius—without the need for separate dedicated stations. In addition, the system’s compact layout optimizes the use of floor space, leaving room for maintenance access and improving operational efficiency. MF
Information for this article provided by Kawasaki Robotics, Inc., Wixom, MI; www.kawasakirobotics.com.
See also: Kawasaki Robotics
Technologies: Finishing, Pressroom Automation
There are no comments posted.MIT Researchers Program Robots to Solve Complex Manipulation...
September 4, 2025
AMRs for Fabricating? You Bet
Lou Kren Friday, November 28, 2025
Well, almost perfect. Proper finishing demands access to all part surfaces as well as a deft touch. In addition, the process must succeed across differently shaped parts with different finishing needs. For these reasons, part finishing has remained primarily a manual process. However, that’s changing, as advances enable improved robot reach, simplified programming of compact tasks, and sensoring and other Industry 4.0 capabilities. And, robotics enable greater quality control and consistent manufacturing processes. The result: ever-increasing real-world applications for robotic finishing—good news for metal formers and fabricators looking for reliable finishing and the freeing of employees for other less monotonous value-added tasks.
Hammond Roto-Finish and Surface Prep conducted a comprehensive assessment to redevelop the entire production process to meet the required part finishes. Also involved: Norton Abrasives, which provided the methods and media to ensure proper surface conditioning.
