Strip Wiper Cleans Material Prior to Feed, Lubrication
February 1, 2017Comments
The new Strip Wiper from Raziol Zibulla & Sohn GmbH, used prior to material feed or lubricant application in the production process, removes dirt particles and residue from prior lubrication to ensure a defined surface quality of the strip material for follow-up processes.
Dirt particles or residue from prior lubrication, such as mill oil, are removed by synthetic felt pressed against the strip material by two pneumatic cylinders. The felt can be automatically moistened with evaporating lubricants to improve the cleaning process. Wear parts, such as the felt, are quickly and easily exchangeable, according to company officials, and a simple retrofit at existing production lines is possible. The Strip Wiper is available with a cleaning width of 50, 100 and 200 mm.
Raziol Zibulla & Sohn GmbH: www.raziol.com
See also: RAZIOL Zibulla & Sohn GmbH
Technologies: Lubrication
