High-Strength Filament Tapes Engineered to Stick to Oily Metal Surfaces
December 1, 2012
3M, St. Paul, MN, has introduced a new proprietary adhesive formulation debuting in a portfolio of Scotch high-strength filament tapes. The new tapes, which use a modified synthetic rubber (MSR) adhesive, prove ideal for metal-coil tabbing, splicing and other applications (sheetmetal drawing, rolling and extruding, for example) involving oily metal surfaces.
After a 2-min. dwell time, the 3M MSR adhesive provides as much as 50-percent greater adhesion, with continued performance over longer dwell times. In addition, its shear strength is equal to or better than natural rubber adhesives. The new portfolio of Scotch high-strength filament tapes featuring MSR adhesive is available in clear and black.
3M: 800/362-3550; www.3M.com/MSR
Industry-Related Terms: Drawing
See also: 3M Abrasive Systems Division
Technologies: Materials
