Transfer Parts and Remove Scrap from Under Press
March 1, 2008Comments
Bunting Magnetics, Newton, KS, will display its standard low-profile conveyors, which need less than 2 in. of vertical clearance to allow the removal of parts and scrap from presses and from other confined spaces. Where several of the conveyors are installed in tandem, a single motor can provide gang-drive power. Standard models are magnetic to provide continuous control of small- to-medium-sized ferrous parts and scrap; metalformers also can use nonmagnetic models.
Bunting also offers its MagSlide chip and parts conveyors (pictured here), built to convey sharp, abrasive ferrous parts and scrap that could damage conventional belt conveyors.
See also: Bunting Magnetics Co.
