Compact AI-powered AMR Handles Payloads to 1500 kg
November 18, 2025
ABB-AMR-P603-Flexley-MoverABB has launched the Flexley Mover P603 platform autonomous mobile robot (AMR), the most compact model in its class to handle payloads to 1500 kg, according to company officials. The P603 combines a compact design with artificial-intelligence (AI)-driven Visual Simultaneous Localization and Mapping (SLAM) navigation and the latest version of AMR Studio software that maximizes flexibility by enabling different modules to be integrated into the AMR.
This AMR is part of ABB's Autonomous Versatile Robotics initiative, where robots can switch seamlessly between tasks, in real time and with minimal effort. With its AI-driven navigation, the AMR P603 reportedly provides smart, rapid and safe operation—meeting ISO 3691-4 and ANSI 56.5 standards—while delivering agility and positioning accuracy of ±5 mm, with no need for reflectors or change in infrastructure. Its differential bidirectional drive system enables smooth movement in tight production and warehouse layouts, while its integrated load-detection capabilities optimize stability and safety during transport.
The P603’s agility and compact design makes it ideal for intralogistics applications, including end of line, goods to robot, line supply, inter-process connection and kitting. It supports a range of load types and dimensions, including open and closed pallets, containers, racks, and trolleys, all handled with a single AMR and flexible top-module configuration.
Designed with modularity in mind, the AMR P603 can be adapted with various top modules to handle different load types. Combined with the AMR Studio upgrade, it enables rapid setup and seamless customization, with system integrators and end users able to build and modify applications using drag-and-drop tools. ABB’s Fleet Manager software is also integrated, allowing users to coordinate multiple AMRs in real time across large and dynamic production environments.
This AMR can be deployed in facilities with both smooth and non-ideal flooring conditions. Top speed: 2 m/s.
Industry-Related Terms: Model
See also: ABB Press Automation Solutions
