New Tool Aligns and Levels Steel Plates
May 1, 2016Comments
Magswitch Technology, Lafayette, CO, a manufacturer of switchable magnets, has introduced a new way to align and level steel plates via the Mag Press with its 1,100 lb. of hold force. Remove highs and lows with ease by placing the magnet on low, prying on high and welding with the other hand. This method allows a user to align two sheets and weld the separate sheets 100 times faster than employing dogs and wedges, according to company officials.
By rotating the unit’s lever to the other side, the Mag Press becomes a beam-press tool that can press 4-6-in. beams in seconds. No more pounding, breaking, grinding or clamping to remove air gaps—just turn the magnet on and push down on the lever to eliminate gaps.
Magswitch Technology: www.magswitch.com.au
See also: Magswitch
There are no comments posted.Kaeser Compressors’ i.Comp Series: Compact, Quiet and Energy...
August 10, 2023
Lift and Tilt Table Lowers to Floor Level for Hand Pallet-Tr...
Thursday, April 4, 2024
Customized AMRs
Friday, March 8, 2024
