Industrial Vacuum Cleaner for Metalworkers
April 1, 2008Comments
The model 55MW industrial vacuum cleaner from Vac-U-Max, Belleville, NJ, increases coolant life and extends machine tool-filtration systems by cleaning fluids and removing metal chips and swarf at 60 to 120 gal./min.
With the turn of a lever, the vacuum cleaner pumps out liquid contents of the drum through the discharge hose to a central filtration system for coolant/oils or approved floor drains to 14 gal./min.
Dual swivel casters makes the 26-in.-wide unit simple to move, and its compact size allows shops to move it close to machine tools and sumps, keeping vacuum hoses as short as possible.
Vac-U-Max: 800/822-8629; www.vac-u-max.com
See also: Vac-U-Max Inc
There are no comments posted. Pressroom Automation
January 2, 2024
Motion Industries Names Esposito Group VP for Motion Automat...
January 2, 2024
Mike Hook July 27, 2023
Conveyors—Four Steps for Maximizing Performance and Minimizi...
Stephan Robertson Tuesday, May 19, 2020
Metal Forming Strategies for Overcoming Economic Crises
