New Tooling System for Optimized Material Handling
December 1, 2019Comments
Norgren Automation Solutions, part of IMI Precision Engineering, Saline, MI, has launched a complete tooling system designed to optimize material handling applications, including in and around press cells. The innovative system, called Transforming Tooling, combines a series of arms driven by electric motion, and offers a number of significant benefits over conventional tooling solutions, including:
- Reduced recurring tooling costs
- Elimination of manual tool change
- Instant tool changeover between applications
- Reduced floor space requirements due to elimination of manual tooling storage
- Optimized safety on the shop floor
When the arms are actuated to the desired location, pneumatic clutches lock them in place, providing a robust and rigid setup similar to conventional end-of-arm robotic tooling solutions. When the application requires a change in handling material, the arms automatically transform the end-effector system to suit the needs for the new application, and lock in place.
The system comes with a full range of IMI Norgren consumables including vacuum cups and grippers that can be swapped on the fly.
See also: Norgren Automation Solutions
Technologies: Coil and Sheet Handling, Pressroom Automation
There are no comments posted.Lift and Tilt Table Lowers to Floor Level for Hand Pallet-Tr...
Thursday, April 4, 2024
Customized AMRs
Friday, March 8, 2024
Omron AMRs With ROEQ Lifter and Roller Modules
Friday, March 1, 2024
