Semi-Automated 3D Scanning
December 1, 2025Comments
New from Zeiss, ScanPort, a semi-automated optical 3D metrology system that reportedly combines accuracy, flexibility and ease of use in a compact setup. ScanPort is designed for users who require reliable metrology results without the need for extensive training or complex setups. It delivers rapid, precise 3D data, and paired with Zeiss’ Inspect software enables even complex inspection processes to be performed with just a few clicks, from CAD comparison and mesh editing to trend analysis.
ScanPort combines a vertically movable axis, a tiltable mechanism and a rotation table to enable true three-axis automation. This allows for optimal illumination and capturing of parts from different angles, according to company officials, who note that a modular, mobile design makes it ideal for use directly on the shop floor or at various locations. The integrated scanner can be detached if required and used separately—to measure larger parts, for example.
A major reported advantage of ScanPort is its simple operation in conjunction with Inspect. Features such as kiosk mode, workflow assistants and preconfigured scanning templates reportedly guide even inexperienced users smoothly through the measurement process. Operation is standardized, as an accurate measurement can be started with only one click. This not only reduces training time but also minimizes potential errors.
And, integrated motion replay function ensures that previously performed scans can be precisely repeated. For recurring parts, this enables a series-ready inspection strategy with consistent evaluation. Deviations between individual parts are automatically detected and visualized, allowing trends in production to be identified and corrected at an early stage.
See also: Zeiss
Technologies: Quality Control
There are no comments posted.Sheet Metal-Inspection Software Module for Creaform Metrolog...
Tuesday, December 9, 2025
Weld Camera for Process Monitoring and Analysis
Wednesday, November 19, 2025
Quality ControlMeasurement System Combines Optical, Probe, Laser and Rotati...
Thursday, November 13, 2025
