Fume Extractor Features Large Capture Zone
November 1, 2019Comments
Miller Electric Mfg. LLC has introduced ZoneFlow technology to its SWX-ZF weld fume extractor, featuring a capture zone that’s more than three times larger than traditional systems, according to company officials. With a capture distance stretching to 5 ft. deep and 4 ft. wide versus the traditional 12 to 13 in., operators no longer must constantly adjust the arm to be close to the source, or not adjust it at all and be exposed to fumes. Thus, operators can continue welding.
ZoneFlow technology moves clean air out of the arm at approximately a 90-deg. angle, creating a large negative-pressure zone that extends capture distance and funnels weld-fume particulate toward the center of the arm to be captured. Previously only available on the company’s FiltAir Capture 5 fume-extraction system, ZoneFlow has been expanded to the FiltAir SWX-ZF wall- or column-mounted system, and is available in a disposable cleaning-filter model.
Technologies: Safety, Welding and Joining
There are no comments posted.Dust Collection for Laser Welding and Cutting
Rick Kreczmer Wednesday, April 26, 2023
Nederman’s Smart Filters Promise to Improve Dust- and Fume-C...
Monday, February 15, 2021
Redesigned Weld-Fume Extraction System
Friday, December 27, 2019
Mobile Fume Extraction
Wednesday, May 22, 2019
