Reprogram sensors to prevent double-stacking and missed parts. Often, defects from double-stacking and skipped parts can be traced back to inconsistent sensor logic. This may require rewriting programs to include verification sequences that ensure proper feed. Doing so will improve quality and throughput.
Adjust hydraulic pressures to stabilize forming operations. Fluctuating forming pressures cause part variation and defects. By calibrating hydraulic pressures to the optimal range, dimensional consistency improves and defects decrease, stabilizing the process.
Build simple fixtures to maintain critical part positioning with less operator intervention. Manual alignment slows production and introduces variation. Constructing and using basic mechanical fixtures can ensure that parts stay in the correct position, reducing operator adjustments and enabling smoother flow. Staffing requirements decrease, allowing operators to focus on value-added tasks elsewhere.
Review the part print to enable speed improvements without compromising quality. Once you have stabilized your process, brainstorm with your team about changes that can be made beyond daily firefighting. For example, look at stamped-part features that can be modified to improve manufacturability. Or you might scrutinize the process for opportunities to improve cycle time. You’ll realize real improvements by giving operators the bandwidth to contribute ideas.
Less Waste Wrings Results
These changes don’t happen overnight. It can take a few weeks to iron out all the issues, but that time is well worth the investment—for the operators, the managers and the ownership. Cycle time will improve with each mechanical fix and process stabilization. Scrap and rework rates drop. Measure the results through carefully tested trials. Each second saved per cycle translates to weeks of extra available production capacity each year.
And those reports that everyone waits for? They’ll reflect how well you’ve managed the process—starting with how you walk the shop floor. The charts will catch up next month, but you’ll already know that the arrows are pointing up. MF
Sensing/Electronics/IOTClearing Faults Press-Control Tales from the Shop Floor
Lou Kren July 28, 2025
Industry 4.0 Applications in the Sheet Metal Forming Industr...
Eren Billur March 27, 2025
Sensing/Electronics/IOTKistler Expands U.S. footprint with New West Coast Regional ...
Monday, November 17, 2025
If you’re waiting for lagging metrics to tell you that something’s broken, you’re already too late. Instead, walk the line and look for where the flow is off. Listen for the subtle changes in rhythm. Engage with the operators—the people closest to the process—and you’ll identify the early signs of waste before the data catches up.
