IO-Link Master Block Combats Noise
October 1, 2019Comments
New from Balluff, the ethernet/IP IO-Link master block, which insulates against inductive, conductive and capacitive noise produced by electromagnetic interference. And, its housing protects against harsh welding environments. It protects against electromagnetic interference that can negatively impact work processes. The nonconductive, nonstick fiberglass-reinforced, polyphenylene sulfide housing does the work of a separate grounding plate and weld splatter slides off. The block’s built-in display enables configuring of network parameters, and its embedded web server allows for remotely configuring the block and connected IO-Link devices.
See also: Balluff, Inc.
