Motorized Bolster Extensions
October 1, 2009Comments
Serapid introduces its motorized bolsterextensions (MBE), which combine the functionality of bolster extensions and push-pull systems into one integrated unit. They support the die outside of the press and move the die in and out of the press. The extensions allow easy access to the side of the press, and can be loaded with an overhead crane or fork truck. Their use of rigid chain technology allows the die to be positioned several inches onto the bolster without special attachments. Capacity: 10 to 25 tons.
See also: Serapid, Inc.
Technologies: Tooling
