All-in-One Lifter for Progressive Dies
June 1, 2008
All-in-one lifter for progressive dies
eliminate the need for additional guiding components.
Complete with a built-in dampening device, the SLN.180 is ideal for progressive dies, and is available with basic and slotted guide-rod options for single, multi-point or rail-lift operations. Dadco’s Micro 180 gas spring, housed inside the guide rod, provides reliable lifting force and facilities rapid, simple repair, according to company officials. The lifter provides on-contact forces ranging from 88 to 450 lb. and is available with stroke lengths from 25 to 125 mm. It comes standard with a keyed narrow-flange mount.
Dadco: 734/207-1100; dadco.net
Industry-Related Terms: Stroke
See also: DADCO, Inc.
Technologies: Tooling
