Compact 1-Ton Nitrogen Gas Spring
September 1, 2008
Dadco’s (Plymouth, MI) new SCR.0800 gas
Compact 1-ton nitrogen gas spring
spring is the latest addition to its compact nitrogen gas spring line. The SCR.0800 has a 38-mm-dia. body with an oversized 25-mm-dia. rod and provides 1 ton of force on contact.
The spring comes with a variety of stroke lengths from 10 to 80 mm, and features a port at the bottom for adjusting pressure, for charging or for linked operation using Dadco’s MiniLink fitting system. The SCR.0800 is available with a variety of mounts and accessories and is completely serviceable.
Dadco: 734/207-1100; www.dadco.net
Industry-Related Terms: Stroke
See also: DADCO, Inc.
Technologies: Tooling
