Five-Axis Vise Allows for Zero-Point Mounting
July 23, 2021Comments
Carr Lane Manufacturing
Booth B23054
The Roemheld PC80 clamping system on display at FABTECH is a simple, compact and cost-effective five-axis vise. The all-steel design is supplied with clamping jaws and offers high precision with process safety. The base of the vise is provided with tapped holes that allow the use of zero-point mounting systems. A center threaded hole allows use with the Quintus riser system from Roemheld.
See also: Carr-Lane Roemheld
Technologies: Tooling
