Tools for Cutting Machines
October 1, 2015Comments
Suhner Industrial Products Corp.
Booth S5007
Suhner Industrial Products Corp., Rome, GA, demonstrates its Somex machining tools, featuring automatic tool clamping and tool release via pneumatic cylinder, designed for heavy-duty sheet and plate cutting in thicknesses to 2 in. These tools typically are integrated with laser, plasma and waterjet machines.
Through-tool coolant is standard, along with spindle tapers of ISO/CAT 40. These precision tools offer spindle concentricity to 0.01 mm. Adapters for servomotor mounting are onboard these Somex tools, which also feature timing-belt drive systems and maximum speeds to 6000 rpm.
www.suhner.com
See also: Suhner Corporation
Technologies: Tooling
