Solar Atmospheres Constructs New Brazing/Assembly Room
December 27, 2019Comments
Solar Atmospheres, Hermitage, PA, has completed construction of a new brazing and assembly room. Though built primarily to accommodate a large aluminum brazing project for a specific customer, the room also will be used for other brazing and assembly work. The temperature- and humidity-controlled room provides a clean environment for the critical assembly and alloying methods employed by Solar. All inventories of the clean components for final assemblies will be safely stored within the new space.
See also: Solar Atmospheres
There are no comments posted. Tooling
Tuesday, February 28, 2023
Fixtureworks Adds to Manual-Clamp Lineup
Thursday, September 29, 2022
Hybrid Multitasking—Machining and Friction Stir Welding
