Page 26 - MetalForming October 2011
P. 26
hydraulic fluid in a flexible rubber blad- der to form sheetmetal using a single tool, producing parts in a range of com- plex geometric shapes. The line was developed and launched in 2008 to replace the original sheet-hydroforming equipment made in the 1960s and 1970s, which can be plagued by high maintenance costs, frequent downtime
and limited availability of replace- ment parts, say Pryer Technology representatives.
The two new Triform presses include the Model 1648BD, with a 16- by 48-in. work envelope; and the Model 2448BD, with a 24- by
48-in. work envelope. Both press- es deliver standard pressure to 5000 psi, with Model 1648BD also available
with 10,000-psi capacity.
Triform presses are compact and
portable, and most models have no special flooring requirements. Their state-of-the-art hydraulics and advanced touchscreen controls can optimize part quality while reducing material and labor costs. The presses come in 10 different models, including those equipped with a hydraulic punch cylinder to allow form- ing of deep-drawn parts with depths up to 13 in.
Pryer Technology Group: 855/864-4670;
www.triformpress.com
High-Speed
Gap-Frame
Hydraulic
Presses
Magnum Press, Jerseyville, IL, intro- duces its MOBI line of 3- to 30-ton open-back inclinable presses. The firm offers a full line
of standard
gap-frame
presses in stan-
dard C-frame con-
figuration, two-
and four-post
guided tool plate,
gib guided and
compact models. Available are a standard hydraulic-press variety from 2 to 250 ton, and broad-reaching custom capabilities to 1500 ton and beyond.
Magnum Press: 618/498-7077;
www.magnumpress.com
STAMTEC SERVO PRESSES
There’s a lot to like in our servo presses: More CONTROL
Tighter TOLERANCES G Gr re ea at te er r C CA AP P PA A A AB B BI I IL L LI I IT T TI I IE ES S
Improved PRODUCTIVITY Enhanced QUALITY
4160 Hillsboro Hwy. Manchester, TN 37355 Phone: 931.393.5050 Fax: 931.393.5060 www.stamtec.com
Deep Drawing
Compound Pressing and Forging
General Forming
Perforation/Blanking
In-Die Heating
24 MetalForming/October 2011
© 2011 Stamtec, Inc. All rights reserved
