Page 59 - MetalForming October 2011
P. 59
Heavy-Duty Pneumatic
Die Lifters
Pacesetter Systems, Inc. Booth 2907
Pacesetter Systems, Inc, Valencia, CA, a manufacturer of quick-die-change sys- tems and metal-stamping accessories,
Fact.
Successful Fabrication Manufacturers Rely on Global Shop ERP.
introduces to show visitors its line of Air Glide heavy-duty pneumatic die lifters. Air Glide lifters are available with ball bear- ings for multidirectional movement or cylindrical bearings for inline movement. Both models feature extra-large, precision- ground bearings and high-quality o-ring seals. With the die lifters, which use stan- dard shop air pressure and install eas- ily in standard ANSI T-slots, it takes just 40 lb. of force to move a 2000-lb. die. Order from stock in 5⁄8-, 3⁄4- and 1-in. sizes, to 72 in. long; custom lengths and met- ric sizes are available.
www.pacesettersystems.com
A Broad Range
of Features and Options for Hydraulic Presses Beckwood Press Co.
Booth 3370
Beckwood Press Co., St. Louis, MO, will demonstrate its latest advances in hydraulic-press technology by exhibiting a modular-construction custom hydraulic press. Beckwood has updated its hydraulic-press offerings (from 2 to 2000+ tons) and automated systems to include expanded technology with a broader range of features and options. Beckwood also will present models from its full line of hydraulic and hydro- pneumatic bench-top presses, and booth visitors can learn about the firm’s expert- ise in compression molding and off- center loading applications.
www.beckwoodpress.com
“Global Shop has made us a much more efficient operation and has allowed us to produce more parts and maintain our on-time delivery at a high rate.” Eric Miller,
Miller Welding and Machine
Use Global Shop Solutions ERP software. Before you know it, you’re saving thousands of dollars. Year after year. Just like our many successful fabrication manufacturing customers.
For a FREE copy of Global Shop’s ROI brochure, visit www.GlobalShopSolutions.com or
call 1.800.364.5958.
Designed to StreamlineTM
©2011, Global Shop Solutions, Inc.
MetalForming/October 2011 57
