Page 32 - MetalForming February 2019
        P. 32
      30
MetalForming/February 2019
Me EFFICIENT PROCESS SOLUTIONS
e
ey
T
MET
ging t nt for t
e
ing e
glob
ion a .
s
eel
ing
o
T
e
nd non-ferr
he pr ous met
nd pr als
T
ion
f t
fi
r
e
ec
hnolo
c
EC
ur
y
a on, s
l
ly l t
o
he highes
W
r
esse
el.
f
www
e
e
a
r
t le
ums f
v
t el w
e
l
ide.
üss
T
com
t
ta
l
n
,w
h
o
it
e
eel a
a
ding e
y m
et
gy a
or new s
a
et
ls
lo
h it
gy Met
s for
heor
Support
g
K
v
nd A
s the 4th European St
v
ent pp
oD
e
s pr
t
ss lic
e or
uch a
el t ldw
F av
T
.m r
a
10
T
TH IN
Energy-Efficient Servo-Electric Punch Press
LVD Strippit introduced its new Strippit E Series servo- electric punch press, offering high energy efficiency and exceptional accuracy for punching and forming applications. The machine delivers 20 metric tons of punching capacity and handles worksheets to
49.2 by 98.4 in. A larger model, Strip-
pit E-1530,
handles sheet
sizes to 60 by
120 in. The
electric drive’s
streamlined
design has
fewer compo-
nents than hydraulic punching machines and fewer parts than most comparable electric punch presses, keeping oper- ation and maintenance costs low while ensuring reliable performance and high uptime.
A 47-station turret provides stations that accept shaped punches and dies, indexable multi-tool, tapping, and wheel tools. A full 0.984-in. feed clearance between the upper and lower turret allows for higher forms such as lances, louvers, embossments or card guides. Precise programmable ram control produces accurate results for forming operations. LVD Strippit: www.lvdgroup.com
Quick-Change Tools for Robot Arms
Suhner Industrial Products’ new quick-change tool system includes power-pack machine tools for direct mounting on robotic arms. The tools feature programmable touch forces of the active flange and interactive surface tracking, allowing automation for
operations pre-
viously unsuit-
able for
automation.
Other features
include pro-
grammable
process forces,
balanced toler-
ances (shapes)
and reduced programming time for complex parts. Performance and process assurance, when compared to known systems such as load cells, can increase significantly, says a company representative. Applications for the robot tools range from automotive to deburring operations, stainless-steel machining to drilling and tapping operations, and all areas of manufacturing and operations.
Suhner Industrial Products: www.suhner.com
For welding-related products, see this article online at www.metalformingmagazine.com. MF
a
ce
a
T
RA
c
s( e
D
ions at
ERNAT
D
i
EF
l
l
A
HC
O
IO
IR W
t
echnologies and applicat
io
n Day
EST
l
el arr
el.
c
do
_ inf
orf N inf
America a.com
T
ET
G
S
NAL M
IT
echnology segment, is the
oduct
oces
A
A
)a
r
e dis
cus
s
N
ES
L
GR
me
Fabrication: FABTECH
tb
U
ES
A
AL
I
w
te
o
ec
om
R
.com
.com
IC
A
AL
