Page 11 - MetalForming December 2019
P. 11
adding two cylinders with 25-in. stroke to achieve speed requirements, reinforcing the press’ structure to accommodate the new cylinders, and developing a cus- tom HMI with recipe handling and data acquisition.
Beckwood service technicians will per- form all work onsite at Branch Manufac- turing’s 66,000-sq.-ft. facility. Once com- plete, the rebuilt press will reach speeds to 410 in./min., up significantly from the original 198 in./min, and include an intu- itive operator control station.
Beckwood Press Co.: www.beckwoodpress.com
New Tooling System
for Optimized
Material Handling
Norgren Automation Solutions, part of IMI Precision Engineering, Saline, MI, has launched a complete tooling system designed to optimize material handling applications, including in and around
to elimination of manual tooling storage
• Optimized safety on the shop floor When the arms are actuated to the
desired location, pneumatic clutches lock them in place, providing a robust and rigid setup similar to conventional end- of-arm robotic tooling solutions. When the application requires a change in han- dling material, the arms automatically
transform the end-effector system to suit the needs for the new application, and lock in place.
The system comes with a full range of IMI Norgren consumables including vacuum cups and grippers that can be swapped on the fly.
Norgren Automation Solutions: www.imi-precision.com/NAS
We make it that easy!
Need tooling? Choose American Punch and we’ll make
getting your tooling as easy as snapping your fingers.
Experienced salespeople you’ll want to work with and can trust. Call us. Email us. Fax us. Order online. We make it easy to order! We’ll work with any part number you have.
Send us your prints! We can make tooling to your exact specs. Most informative and easy-to-use website with
immediate quote via Chat Now window.
Call today! Get the right tooling now for your application!
www.AmericanPunchCo.com | 800.243.1492
9001:2015
CERTIFIED
press cells. The innovative system, called Transforming Tooling, combines a series of arms driven by electric motion, and offers a number of significant benefits over con- ventional tooling solutions, including:
• Reduced recurring tooling costs
• Elimination of manual tool change • Instant tool changeover between
applications
• Reduced floor space requirements due
MetalForming/December 2019 9
