Page 32 - MetalForming April 2009
P. 32
Tooling Technology ToolingUpdate
QDC Clamp for Dies with a Flat Edge
Serapid, Inc., Ster- ling Heights,
MI, intro-
duces the PSH
C-clamp to its
line of quick-die-
change clamps. The
PSH, designed to work
with dies with a flat edge,
mounts on a T-profiled base to form a bracket device, which then is manually inserted into a slot on a press bolster or slide. During an automated die change, the clamp head alone can be mounted
permanently on the press.
The clamp is hydraulically activated
and opened with a spring, and comes in a variety of force ratings from 20 to 100 kN. Clamping height can be indi- vidually configured through the height of the base piece or through the use of
a custom-sized spacer.
Serapid: 586/274-0774; www.serapid.us
Transfer Roller Bars Without Lift
Hilma Division of Carr Lane Roemheld Mfg., Ellisville, MO, introduces a new transfer roller bar that promises high load-
bearing capacity without hydraulic lifting. Use the bars on die tables outside of the press with lifting roller bars in the press bolster to provide sim- ple and convenient die transfer. Segments can mount front to back to any desired length, or can be used in rows of two to double load-bearing capacity. The units
come in three sizes.
Hilma Div. of Carr Lane Roemheld: 800/827-2526; www.clrh.com/hilma
30 METALFORMING / APRIL 2009
write no. 22
