Page 29 - MetalForming July/August 2009
P. 29
The TDL2 is offered in bore sizes in diameters from 40 to 100 mm and in stroke lengths from 25 to 400 mm. The TDL4 is equipped with a 40-mm-dia.-bore air cylinder available in stroke lengths from 25 to 250 mm.
Dadco: 800/323-2687; www.dadco.net
Storage Carts Designed for Press-Brake Dies
Proper Storage Systems, Inc., Seguin, TX, introduces stor- age carts—64 in. tall—that conveniently store press-brake dies on roll-out shelves. Each shelf offers 1500-lb. capacity and con- tains 10 sets of adjustable blocking to accommodate a variety of die sizes. Shelves, adjustable on 1-in. centers, meas- ure 30 in. deep, with widths of 48 and 96 in. Order units with three or four shelves and with 7 or 11 in. of clear space between shelves. When one shelf is rolled out for die access, an auto-
matic safety interlock locks the other shelves.
Proper Storage Systems, Inc.: 800/516-0138;
www.properstorage.com
Ball-Bearing Assemblies Mount Directly to Die and Punch Holders
Anchor Danly, Farmington Hills, MI, introduces a low-cost surface-mount ball-bearing component assembly that mounts directly to the die and punch holders, rather than the con- ventional method, as an alternative to its die-components guid- ing system product line. The assemblies come in 32-, 38-, 50- and 60-mm dia., with length from 100 to 350 mm. Complete assemblies include mounting bolts and dowel pins; tapped mounting holes, to secure stroke end blocks, are optional. Anchor Danly: 440/239-7600; www.anchordanly.com
Die-Design Provider Forms Partnership in Monterrey
Accurate Die Design, Inc., New Berlin, WI, the North American distributor and technical center for Logopress die- design software, has formed a partnership with Cad Avshmeip S.A., Monterrey, Nuevo Leon, Mexico. Cad Avshmeip, which offers products and services for CAD, CAM, CAE, DNC, and reverse engineering and inspection, will handle technical support and training for Accurate Die Design’s prospects and users of Logopress3 three-dimensional die-design software.
Accurate Die Design: 262/938-9316;
www.accuratediedesign.com
write no. 17
