Page 27 - MetalForming October 2009
P. 27
• Where to look for early signs of problems;
• Simple items to add to your PMs that will offer great payback; and
• New technologies that can be used to detect unseen problems.
Options for Press Repair and Modernization—Peter Campbell, Campbell Press Repair
This presentation sheds light on where presses tend to fail and what parts will be affected if maintenance is deferred.
• What parts typically break on a press;
• What are some of your options
when a failure occurs; and
• What you can do to avoid com-
mon mistakes in press operation.
10:30 a.m. – 12:30 p.m.
Session S30
Stamping Advanced
High Strength Steels II
Gaining a Competitive Advantage through In-Die Fastener Installation Systems—Roger Patton, PennEngineering
A multimedia presentation including detailed animations of the in-die fas- tening process and several case studies.
• Why in-die fastener-insertion sys- tems add value;
• How in-die fastener-insertion systems work;
• Determining the ROI of in-die systems; and
• Proper implementation of an in- die system.
Designing Dies for High-Strength- Steel Stampings—Peter Ulintz, Anchor Manufacturing Group, Inc.
Recent die-process research has proven the effectiveness of several unique methods that address problems specific to advanced high-strength steels, including the selection of opti- mum stamping processes and equip- ment, solving formability issues, con- trolling springback, selecting die steels for optimal tool life and establishing product-design strategies to ensure manufacturability.
• Die-design considerations;
• Die maintenance considerations; • Pressroom considerations; and
• Methods for managing springback.
Solution is Right for You!
A wide range of models, tonnages,
With Hundreds to Choose From... Only One SEYI
bed sizes...you bet!
Just as important is how we listen to your needs, then build a solu- tion that works best for you.
Often, we'll build a custom system engineered from our standard product line (outfitting it with needed automation, tooling, or coil handling).
Gap Frames Presses to 330 tons. Single- and double-point designs available.
Straightside Presses to 2,400 tons. Single-, two-, or four-point designs; crank or eccentric gear driven presses available.
Link Motion Presses to 2,400 tons. Single- and double-point designs. Link motion reduces the working stroke’s velocity up to 40% for better overall productivity and part quality.
Servo Drive Presses. Contact us for more information on our new line of SD1 Series.
“SayYes” to a SEYI press. Contact us today.
SEYI PRESSES, INC.
California Office
203 Lemon Creek Dr, #A Walnut, CA 91789
TEL: 909-839-1151
FAX: 909-839-1150
Tennessee Office
843 Joint Park Blvd Tullahoma,TN 37388 TEL: 931-455-7700 FAX: 931-455-6092
write no. 18 OCTOBER 2009 25
www.seyi.com
sales@seyiamerica.com
