Page 32 - MetalForming October 2009
P. 32
    METALFORM
Previews
These MetalForming advertisers will be exhibiting in Chicago. Go to www.metalformingmagazine.com/previews to find more booth previews.
        Tapping Tools Eliminate Secondary Threading Operations
Wilson Tool Intl. booth 6131
New tapping tools to be displayed by Wilson Tool save time and help fabricators achieve their lean-manufacturing goals by elim- inating secondary threading operations. Wilson tapping tools for punch presses form threads with a higher tensile
strength than those cut by conventional
machine tapping, and allow fabricators to tap
a threaded hole with every machine stroke,
at up to 200 holes/min. Tools are available
for most brands of turret-style punch presses.
Visit www.wilsontool.com/punching/WTV_Tapping.html for a demonstration.
www.wilsontool.com
Tooling Sets, Marking Tools, Die Springs, More
Dayton Progress Corp. booth 16136
Dayton Progress will introduce a variety of new products at the FABTECH & AWS Welding Show including METALFORM exhibition, including its DaySet compound tool- ing sets, Cumsa in-die marking tools, JIS die springs, thread-form tools, DayStrip steel stripper units and the innovative DayLube nano ceramic lubricating grease. DaySet is a complete system for producing washers in a single-step operation without a pro- gressive die. Cumsa marking tools, which provide traceability for sheetmetal parts, can be surface mounted in a die, mounted in a pocket, or cam mounted for angu- lar surfaces.
www.daytonprogress.com
Multi-Process Weld Power
Lincoln Electric Co. booth 36043
Lincoln Electric displays its portable Power Wave S350
multiprocess
arc-welding
power supply,
ideal for con-
struction, aero-
space, fabrica-
tion, automotive
and production
welding. Capa-
ble of shielded-metal-arc, DC and pulsed- DC gas-tungsten-arc, gas-metal-arc and pulsed gas-metal-arc, and flux-cored arc welding, it features PowerConnect technology for automatic input voltage reconnection, a Tribid power module to maintain overall efficiency and power, and Production Monitoring 2 software to track weld data.
Also on display: Accu-Pak boxes of the firm’s SuperArc weld wire, easy to trans- port as corrugated-cardboard mini-pallets for a 500-lb. box and wooden mini-pal- lets for a 1000-lb. box. www.lincolnelectric.com
  30 METALFORMING / OCTOBER 2009
   30   31   32   33   34
