Page 45 - MetalForming October 2009
P. 45
Push/Pull Die-Loading
System
Pacesetter Systems, Inc. booth 14072
Pacesetter Systems, Inc. showcases the Power Pallet, for die load and unload.
Double Valve for
Clutch/Brake Control
Ross Controls booth 17102
Ross Controls
introduces its
DM2 series D dou-
ble valve for control
of clutch/brake
mechanisms,
which provides
total dynamic moni-
toring with complete
memory and Category 4 control reliabil- ity. The valves have a dirt-tolerant, wear- compensating poppet design and can be fitted with an optional status indicator. Sizes: 4, 8, 12 and 30, with additional versions coming soon.
Also on display: the firm’s automatic- counterbalance systems—flexible assem- blies with built-in manual and auto- matic circuits. These units monitor and ensure counterbalance pressure is cor- rect every cycle of the press. www.rosscontrols.com
High-Speed Presses
and Much More
Bruderer Machinery Inc. booth 16030
Bruderer Machinery will showcase its complete line of presses, as well as its line of support equipment including
payoffs, accumulators, strip welders, servo-feed units, in-die sensing tech- nologies, visual-inspection systems, parts washers, in-progression strip welders and take-ups.
www.bruderer.com
The unit attaches to a forklift and can push/pull as much as 6000 lb. of die weight. Less than half the size of a die cart, it proves easy to store.
Laser-equipped for pinpoint dock- ing, the pallet docks on the bolster of any standard press, ready to load or unload dies with the push of a button. www.pacesettersystems.com
Hot Stamping Press,
Benchtop Hydraulic Presses
Beckwood Press Co. booth 17021
New at the Beckwood Press Co. booth is a hot-stamping press, developed along with Hastings Manufacturing, and the
firm’s new Active-Leveling Control (AVC) system, equipped with the latest in four- corner parallelism and HMI control fea- tures. Also on display will be Beck- wood’s range of hydraulic presses, including a demonstration of its bench- top and hydroforming models. Booth visitors also can learn about the firm’s expertise in compression molding and off- center loading applications. www.beckwoodpress.com
Saf-T-Vanish Contains No VOC’s
Saf-T-Vanish is a Direct Replacement
for Solvent-Based Disappearing Lubricants used in Stamping & Roll Forming Operations
Saf-T-Vanish:
FAST DRYING
EXCELLENT CORROSION PROTECTION NON-FLAMMABLE
SAFEST HEALTH RATING
HIGH LUBRICITY
NO MIXING REQUIRED
“ASK FOR A FREE SAMPLE”
TowerOil&TechnologyCo.
773-927-6161 • www.toweroil.com
write no. 37
OCTOBER 2009 43
