Page 49 - MetalForming November 2009
P. 49
UPON INSTRUCTION FROM THE SECURED CREDITORS
PUBLIC AUCTION THURSDAY, DEC. 3 @ 10AM EST
Preview and Inspection on Wednesday, December 2nd from 9am - 4pm
TRANSFER PRESS LINE
1997 CLEARING NIAGARA LE2-1000-180-72 1000 Ton Straight Side Link Drive Two-Point Press, Stroke 24”, Strokes per Minute 15-30 Variable, Full Tonnage at .5” Above Bottom Stroke, Bed 72” x 180”, Shut Height 54”, Motorized Adjustment 16”, T-slotted Bolster Plate, Windows 78” Wide, Wintriss Smart Pac, S/N P-54393; Coe Servo Feed LIne: Reel Mdl CPR-PO-20042, S/N 15087-4, Capacity 20,000 Lb, Width 42”, ID 19.5” - 24.5”, Hydraulic Expansion, OD 72”, Coil Car; Coe Mdl CPPS-PO-350-42 Straightener, Capacity 42” x .140” Thickness, 7-Straightening Rolls, Entry & Exit Pinch Rolls - Pneumatic Lift, Debender, Powered Hold Down Arm, Peeler; Coe Mdl CPDTT-4214 Threading Table; Coe Model CPRF- 542 Servo Feed, Cabinet Power Height Adjustment • ATLAS 120,000# Capacity Die Train, 92” x 418”, 30 FPM, S/N G316.13; 60,000# Die Train, 84” x 180”, 15-30 FPM, S/N G316.03
SERVO COIL FEED LINES
PERFECTO 20,000# x 42” Wide x .078” Servo Feed Line: Reel Model RS20-42, ID 19.5” - 24.5”, Hydraulic Expansion, OD 60”, Hydraulic Expansion, Adjustable Base, Travelling Coil Car, S/N R6-89156; Straightener Model #28-42-7, Hold Down Roll, Peeler, Entry & Exit Pinch Rolls, S/N S4-89157; Threading Table; Servo Feed Model 500-42, Power Height Adjustment, Roll Diameter 5”, S/N EE-89157 • COE 20,000# x 30” Wide Servo Feed Line: Reel Model CPR-PO-20030, ID 19” - 24”, Hydraulic Expansion, OD 60”, Travelling Coil Car, S/N 12031- 4; Straightener Width 30”, Hold Down Arm, Peeler, Entry & Exit Pinch Rolls - Pneumatic Lift; Threading Table Model CPTT-3015; Servo Feed, Cabinet Power Height Adjustment • PERFECTO/COE 20,000# x 36” Servo Feed Line: Perfecto Reel Model RS-20-36B, ID 19.5” - 24.5”, Hydraulic Expansion; OD 60”, Coil Car; Coe Straightener Model CPPS-PO-350-36, Entry & Exit Pinch Rolls, Hold Down, Peeler, S/N 8762-1; Threading Table; Coe Servo Feed Model CPRF-536, Roll Diameter 5”, Indramat Feed Console, S/N 1094143 • COE 6,000# x 24” Servo Feed Line; Double End Reel Model CPR-DE-PO-6024, Width 24”, OD 60”, Hold Down Arm, S/N 12620-3; Coe Straightener Model CPPS-PO-300-24, 7 Straightening Rolls, Entry & Exit Pinch Rolls, S/N 12620-2 • COE CPRFSM-224 24” Servo Feed, Width 24”, Roll Diameter 2”, Servo Master Control, S/N 22819-1 • COE 20,000# Model CPR-PO-20030 Reel, Width 30”, Hydraulic Expansion, OD 60”, Motorized Hold Down Arm, Peeler, S/N 8414-3; Coe Model CPPS-PO-350-30 Straightener, Width 30”, 7-Straightening Rolls - 3.5” Dia, Debender, Entry & Exit Pinch Rolls - Pneumatic Lift, S/N 8414-3; Coe CPTT-3018 Threading Table
STRAIGHT SIDE PRESSES
VERSON S4-600-144-84T 600 Ton Straight Side 4-Point Press, Stroke 14”, Strokes per Minute 16 & 24, Bed 60” x 144”, Shut Height 34”, Motorized Adjustment 12”, T-slotted Bolster Plate 9.5”, Windows 60” Wide, Air Cushions, S/N 21751; Coe 60” Servo Feed, Model CPRF-760, Width 60”, Roll Diameter 7”, S/N 12280-1A-B Panelview Control; Coe Threading Table • NIAGARA BP2-600-84-42 600 Ton Straight Side Double Crank Press, Stroke 12”, Strokes per Minute 20-60 Variable, Bed 42” x 84”, Shut Height 36”, Motorized Adjustment 16”, T-slotted Bolster Plate 54”x84” x 7”, Windows 31” Wide, • (3) NIAGARA BP2-500-144- 60 500 Ton Straight Side Double Crank Presses, Stroke 14”, Strokes per Minute 20-45, Bed 60” x 144”, Shut Height 36”, Motorized Adjustment 12”, Cam 1500 PLS, Smart Pac, Light Curtains, S/N 50600, 50601 & 50602 • NIAGARA PN-260-84-48 260 Ton Straight Side Double Crank Press, Stroke 6”, T-slotted Bolster Plate 3.5” • NIAGARA SC2-250-96-54 250 Ton Straight Side Double Crank Press, Stroke 16”, Strokes per Minute 18, Bed 54” x 96”, Shut Height 36”, Motorized Adjustment 11”, T-slotted Bolster Plate 4.75”, Windows 23” Wide, Smart Pac, S/N 45798; Coe Servo Feed, Width 24”, ServoMax Control • FEDERAL S2- 250-72-42 250 Ton Straight Side Double Crank Press, Stroke 6”, Strokes per Minute 60-120 Variable, Bed 42” x 72”, Die Height 14”, T-slotted Bolster Plate 48” x 72” x 6” thick, Windows 20” Wide, Smart Pac, S/N S2-224; Rowe Model PM-FAC-053-215 Servo Feed, Capacity 15” Wide x .135”, S/N 28874 Servo Feed, Capacity 15” Wide x .135”, S/N 28874 • NIAGARA S2- 250-72-42 250 Ton Straight Side Double Crank Press, Stroke 12”, T-slotted Bolster 48” x 72” x 5.75”, Riser in Uprights 10”, Smart Pac, Shadow V Light Curtains, Windows 19” Wide; Coe Model CPRF324 Servo Feed, Width 24”, Roll Diameter 3”, S/N 10376-1 • MINSTER E2-200-60-48 200 Ton Hevistamper Straight Side Double Crank Press, Stroke 6”, Strokes per Minute 0-120 Variable, Bed 48” x 60”, Shut Height 21”, Motorized Adjustment 6” • MINSTER E2-200-60-54 200 Ton Hevistamper Straight Side Double Crank Press, T-slotted Bolster 3.5”, Windows 24” • (7) NIAGARA SC2-150-84-48 150 Ton Straight Side Double Crank Press, Stroke 10”, Strokes per Minute 28, Bed 48” x 84”, Shut Height 24.5”
TUBE END FORMING AND SIZING
MCKEE FM-70 DIGI II Tube End Sizer, S.O. 79990, Capacity 2.75” OD, A-B Panelview 550 • (8) EAGLE I/O Tube End Sizers, Capacity 2.75” OD, 10 HP Hydraulic Unit, S/N 2778, 2616, 2228, 2003, 1611, 1469, 731138B • MANCHESTER M.82-H-3 Tube End Former • And More
ALSO INCLUDING:
OPEN BACK INCLINABLE & GAP FRAME PRESSES HYDRAULIC & PNEUMATIC PRESSES • INSPECTION • ROBOTIC WELDING CELL & ROBOTIC INSERTION CELL • WELDERS AUTOMATIC TUBE SEAM WELDING CELLS • AUTOMATIC TUBE ASSEMBY CELLS • TOOL ROOM • FABRICATING EQUIPMENT
DRAWING/FORMING DIE MATERIAL
Special-formulated, hardened copper alloy that reduces or eliminates galling and scoring in your dies.
• Replaces Hardened/ Coated Tool Steels.
• Reduces Maintenance Repair Time and Cost.
• Increases Tool Life.
• Exceptional Thermal Conductivity.
• WELDABLE
• Sankyo’s proprietary DieAceTM die material is a dependable, customer- proven performer.
Contact your local Sankyo Technical Representative for more information.
Phone: (586) 254-3100
Website: www.sankyo-oilless-usa.com Email: support@sankyo-usa.net
write no. 32
Invitation to sign up for a Free Subscription to a site created for you!
Started in January 2008, to serve North American tool & die, stamping, molding and precision machin- ery industry.
• 100% free and easy to sign up
• #1 Tool and Die Blog (Google and Yahoo!)
• Latest news commentary, post and find jobs, fight misperceptions and more
• Find information on auto and non-auto tooling such as alternative energy
Go to www.toolanddieing.com
Go to www.toolanddieing.com and find the “Subscribe Via Email” input box on the right side of the page
Created and managed by:
Lintrio Marketing www.lintrio.com
Joe Brown
P: 248-860-0965 • F: 248-565-4460 e: info@lintrio.com
FINISHING
EQUIPMENT •
CRANES • ROLLING STOCK
21700 Northwestern HWY Suite 1180
Southfield,MI 48075
Ph 248.569.9781
Industries (1991) Inc.
Fx 248.569.9793
write no. 33
