Page 17 - MetalForming February 2010
P. 17
Robotic Welder Prevents a Downstream Bottleneck
“The key benefit is throughput,” stresses Belzer. “That’s because we have combined the CL-850 with a robotic welder in a processing cell. Work from the cutting system feeds directly to the robot, and the precision and consisten- cy of laser cutting ensures optimal part fitup for welding, minimizing process- ing time and material handling.”
For example, Belzer notes that pro- cessing time has dropped by more than half, when fabricating galvanized steel for irrigation-system control panels. Laser cutting eliminates hard tooling for such parts, which have a number of cutouts, he says.
Also helping to slash processing time is the addition of dual quick-change pallets to the laser-cutting system, which enables an operator to load and unload pallets offline while the system cuts work on the second pallet. The CL-850 fea- tures two 6- x 12-ft. pallets, compared to the single 5- x 10-ft. cutting table on Lindsay’s older laser-cutting machine.
“Pallet change takes just seconds,” says Belzer, “enabling nearly nonstop cutting efficiency. By comparison, we had to stop our previous single-bed laser to remove finished parts and reload material for the next cutting cycle.”
Batch Processing Optimizes Material Yield
In all, the new machine processes several hundred different part num- bers, primarily mild steel 1⁄4 in. and thinner. Lindsay machine operators program parts and jobs, a process that begins by downloading AutoCAD draw- ings directly from the mainframe to the laser. Cincinnati’s nesting software then is used to batch parts for opti- mum material yield.
“The laser processes four different material thicknesses in a typical shift,” says Belzer, “allowing versatility of scheduling and enabling nesting and batch processing of common-thickness parts.” MF
Article supplied by Cincinnati Inc., Cincin- nati, OH: 513/367-7100; www.e-ci.com.
Press Controls For All Presses
One Source
One Solution
Toledo Integrated Systems
Press Pilot 150 Control
We Provide Solutions For...
Mechanical Presses Hydraulic Presses Forging Presses Transfer Presses
Maximizer TPC (Total Press Control)
Toledo Integrated Systems Toledo Transducers, Inc.
www.ToledoIntegratedSystems.com 800-T-Toledo 419-876-4170
METALFORMING / FEBRUARY 2010 15
