Page 31 - MetalForming February 2011
P. 31
fact, he’s certain that the job would have been lost at quotation if it was not determined that the product was feasi- ble in one draw. StampingSimulation.com: 866/617-8267; www.stampingsimulation.com
Deburr Tool Eliminates Burrs and Secondary Operations
Mate Precision Tooling, Anoka, MN, introduces the Rollerball Deburr tool to eliminate burrs and secondary operations for users of CNC punch presses. Use it to deburr mild steel, stainless steel and aluminum sheet of any thickness. The tool fits thick-turret and Trumpf-style applications, and incorporates Mate’s pro- prietary Rollerball technology that uses
Gas Spring—Same Height, Double the Force
Dadco, Plymouth, MI, has introduced the UX.1600 nitrogen gas spring, the latest addition to its Ultra Force Extended Series. The 1.7-ton UX.1600 matches the 3⁄4-ton ISO standard-size full-height gas spring in overall length, with twice the amount of force on contact. It has a 63-mm-dia. body and is available with stroke lengths from 25 to 200 mm. It has linking capability through its G 1/8 port and is offered with a variety of mount options. Other models include the UX.1000 (1.0 ton), UX.2600 (2.6 ton), UX.4600 (4.7 ton), UX.6600 (7.4 ton), UX.9600 (10.7 ton) and UX.20000 (22 ton). Dadco: 734/207-1100; www.dadco.net
Tooling Technology
Hilma Introduces MAGNETIC Quick Die Change
clrh.com/hilma
Hilma has been safely clamping dies for more than 50 years. Now, HILMA intro- duces new M-TECS MAGNETIC quick die change systems.
• Clamps existing dies without retooling
• Evenly distributed clamping force reduces
tool wear
• Superior multi-level safety system
• Custom engineered to the application.
Contact Hilma Engineering for more information.
16345 Westwoods Business Park Dr. Ellisville, MO 63021
(636) 386-8022 • Fax (636) 386-8034
For Technical Support Call (800) 827-2526 Email: engr@clrh.com
SEND FOR FREE INFORMATION
the extended programming capabilities of punch presses operating in the x and y axis with the ram down.
Using a special ball in both the upper and lower part of the tool, the Rollerball Deburr pushes the burr away, creating a slight radius on the punched edge. Smooth to the touch, the deburred edge is consistent and has a finished, aes- thetically pleasing appearance. All part contours can be processed with the Rollerball Deburr tool, including small, tight corners.
The tool comes as a complete set including springs for adjusting tension appropriate for the material being punched.
Mate Precision Tooling: 800/328-4492;
www.mate.com/rollerball
MetalForming/February 2011 29
