Page 10 - MetalForming April 2011
P. 10
Low-EAU Part Better Off Fabricated than Stamped
Claiming the project to be the “first fruits of its new fabrication department,” Ultra Tool & Manufacturing, Menomonee Falls, WI, recently saved a customer more than $120,000 in up-front tooling costs to produce a low-EAU (estimated annual usage) part. The part in question:
a hydraulic pump-bracket assem- bly for the Nissan Murano con- vertible. Progressive dies needed to stamp the assembly’s three parts would have cost $138,000, a hefty up-front investment for an EAU of only 6000.
Instead,
Ultra Tool man- ufactured the
parts in its new fabrication department, boasting a Salvagnini L1Ce fiber-laser cutting machine and a Durma 150-ton CNC press brake.
“Typically we look for a maximum 2-yr. payback to justify pro- gressive tooling,” says Matt Schemelin, an
Ultra Tool sales engineer. “With such a low EAU, payback for the progressive tool- ing for this job would have taken more than 8 yr.”
Ultra Tool added its fabrication department during the summer of 2010 to accommodate lower volume orders. Its Salvagnini laser-cutting machine (left) boasts a 60- by 120-in. work- table, 3000-W laser and positioning tol- erance of ±0.0004 in. Cutting capacity
“SMART” HYDRAULIC PRESSES
20-ton assembly press with enclosed C-frame design for near-zero deflection, precision electronic control of ram force, position and speed, convenience port for ethernet commands to PLC, customized hydraulic features, and touch screen HMI with multiple recipe storage.
Custom engineered to integrate with today’s shop floor
technology.
Our high-tech, special-purpose presses, designed to meet your most demanding requirements, are the most accurate and productive machines we’ve ever built.
Call Gene at 614-228-0185, ext. 231 for details and an eye-opening quote.
www.multipress.com
8 MetalForming/April 2011
